FLASH ans SRAM use share bus?
Hi
The flash and sram must use the share bus?
I want to ask if I can use modify the .ptf to make the flash and sram have themsleves' address signal
and data signal .
Thank you .
Hi Sun2004,
You can change the pin sharing option in SOPCBuilder. Just uncheck the
the sharing box in the SDRAM configuration -- then regenerate the
system.
--Scott
