FPGA square root display
I have written the following program to determine the square root of a number but i m getting difficulty how to display the result ? I have used the mega functions to find the square but unable to proceed as to how to go about displaying the decimal number say square root( 2) = 1.414 on the DE1 board .
will be really thankful if some one could help !
library ieee;
USE ieee.std_logic_1164.all;
Entity squareroot is
port (
clock_50 :in std_logic ;
SW : in std_logic vector (9 downto 0);
HEX3, HEX2,HEX1,HEX0 : out std_logic vector (6 downto 0);
End squareroot;
architecture topelevel of squareroot is
Component integertoFloatingpoint IS
PORT
clock : IN STD_LOGIC ;
dataa : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR (31 downto 0
END integertoFloatingpoint;
Component squarerootTofloatingpoint IS
PORT
data : IN STD_LOGIC_VECTOR (31 DOWNTO 0);
result : OUT STD_LOGIC_VECTOR (31 DOWNTO 0)
END squarerootTofloatingpoint;
Component flotaingpointTofixedpoint IS
PORT
END flotaingpointTofixedpoint;
you will need to work out the number in base ten to display it like you want.
You also need to feed in the input from somewhere!
If you are just doing experiments it might be sensible to add a nios cpu and put your logic as an Avalon slave. Then you can use the JTAG UART for IO.
