Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
FPGA-to-HPS SDRAM Bridge in Bare-metal
I am using DE1-SoC to start bare-metal programming for dual-core Cortex-A9 ARM hard processor, Cyclone V.
I'm trying to read data from SDRAM to FPGA using FPGA-to-HPS SDRAM Bridge.
I configured FPGA-to-HPS SDRAM interface in qsys to use avalon-MM Read only, 32 width.
I exported FPGA-to-HPS SDRAM Bridge avalon-MM Read only and write verilog state machine for reading
always @ (posedge DDR3_clk )
begin
if(sdramState == READ) begin
DDR3_read <=1'b1;
DDR3_write <=1'b0;
if(DDR3_waitrequest==1'b0 && DDR3_read==1'b1)begin
if(!wrfull_vga_fifo ) begin
if(sdram_rd_cnt == (0 + 110591) ) begin
sdram_rd_cnt <= 0;
end else begin
sdram_rd_cnt <= sdram_rd_cnt + 1'b1;
end
DDR3_address <= sdram_rd_cnt; //+ A_FRAME_SA;
data_to_vga <= DDR3_readdata[15:0];
wrreq_vga_fifo <= 1'b1;
end else begin
wrreq_vga_fifo <= 1'b0;
end
end else begin
end
end
end
And I build preloader using bsp-editor.exe and load it using Eclipes of DS-5.
When I traced FPGA-to-HPS SDRAM Bridge "avalon-MM Read only signals" on signalTab, The output was:
avalon_DDR3_waitrequest signal was always 1.
Then I added in main():
alt_bridge_init( ALT_BRIDGE_F2S, NULL, NULL);
The output was:
avalon_DDR3_waitrequest became 0 but still no data read ( avalon_DDR3_readdatavalid was always 0, and avalon_DDR3_readdata was always 0).
