FPGA-to-HPS SDRAM Bridge in Bare-metal
I am using DE1-SoC to start bare-metal programming for dual-core Cortex-A9 ARM hard processor, Cyclone V. I'm trying to read data from SDRAM to FPGA using FPGA-to-HPS SDRAM Bridge. I configured FPGA-to-HPS SDRAM interface in qsys to use avalon-MM Read only, 32 width. I exported FPGA-to-HPS SDRAM Bridge avalon-MM Read only and write verilog state machine for reading .. always @ (posedge DDR3_clk ) begin if(sdramState == READ) begin DDR3_read <=1'b1; DDR3_write <=1'b0; if(DDR3_waitrequest==1'b0 && DDR3_read==1'b1)begin if(!wrfull_vga_fifo ) begin if(sdram_rd_cnt == (0 + 110591) ) begin sdram_rd_cnt <= 0; end else begin sdram_rd_cnt <= sdram_rd_cnt + 1'b1; end DDR3_address <= sdram_rd_cnt; //+ A_FRAME_SA; data_to_vga <= DDR3_readdata[15:0]; wrreq_vga_fifo <= 1'b1; end else begin wrreq_vga_fifo <= 1'b0; end end else begin wrreq_vga_fifo <= 1'b0; end end end And I build preloader using bsp-editor.exe and load it using Eclipes of DS-5. When I traced FPGA-to-HPS SDRAM Bridge "avalon-MM Read only signals" on signalTab, The output was: avalon_DDR3_waitrequest signal was always 1. Then I added in main(): alt_bridge_init( ALT_BRIDGE_F2S, NULL, NULL); The output was: avalon_DDR3_waitrequest became 0 but still no data read ( avalon_DDR3_readdatavalid was always 0, and avalon_DDR3_readdata was always 0).Link Copied
