I tried to use the general Avalon-MM DMA controller in Qsys and use the following C code to implement the DMA transmit:# include <stdio.h># include "system.h"# include "io.h"# include "sys/alt_dma.h"
# define CUSTOM_BASE_ADDR 0x00800000
int i = 0;
alt_u32 data ;
alt_dma_txchan tx;
int main()
/*fill the array*/
for(i=0;i<10;i++)
data = i;
/*DMA*/
tx = alt_dma_txchan_open("/dev/dma_import");
if(tx != NULL)
printf("DMA TX channel open\n");
if(alt_dma_txchan_ioctl(tx, ALT_DMA_TX_ONLY_ON, CUSTOM_BASE_ADDR)<0)
printf("Error: Failed to configure the DMA\n");
if(alt_dma_txchan_send(tx, data , 5, NULL, NULL)<0)
printf("Error: failed to post transmit request\n");
else
printf("DMA done\n");
alt_dma_txchan_close(tx);
else
printf("Error: Failed to open tx channel!\n");
return 0;
Where the array is stored in an external memory while the CUSTOM_BASE_ADDR is a separate peripheral. The connection among NIOS, external memory and custom peripheral should be fine since I've tested with general reading/writing. Turned out "alt_dma_txchan_send(tx, data , 5, NULL, NULL)" always failed. Currently I'm not sure if the problem lies in the hardware part or the software. Please suggest if there's any problem in the above code. Thanks!
