12604 Discussions
First Nios project works with Nios2/e but not with Nios/sf
Hi all
I'm a very beginner with nios II and I have some problems with the first simple test:
I have a cheap "chinesse" CycloneII mini-board with 16 MB sdram and I created a SOPC with:
- Nios 2/e ( Nios2 /s)
- JTAG uart
- PIO (1 output)
- SDRAM controller
- EPCS controller
With Nios 2 SBT , selecting the template "hello world." I've created my first test, and works perfectly with the Nios2/e CPU , but after re-generating the SOPC with the cpu Nios2/s and remake the project, the board doesn't send the famous message to the Nios Console.
Can someone help me ????
Thx very much
NIOS II/e is free, but /s and /f require a license.
Assuming you don't have a license, you may be able to use them in time/tethered evaluation mode.
Thank you, I don't have a license, it is my first soft core try, i will take a look at opencores.
