12437 Discussions
Fitting a clock on a CycloneIV GX device with 115K Elements
Good morning,
As I'm not sure where to post this topic, I submit it here.
I am currently developping on a CycloneIV_GX115. The manually crafted VHDL code works fine as far as I can see. However, in order to implement some functions, I have tried to switch the design to a NIOS_II processor which uses 32K M9K RAM plus a 128K ROM.
With the NIOS II processor, the clocks that were previously fitting on the hard coded VHDL don't anymore. I get a message from the fitter with the input PLL I have put on the primary clock :
error (176559): can't place mpll or gpll pll "pll_64_to_40:pll_inst|altpll:altpll_component|pll_64_to_40_altpll:auto_generated|pll1" in pll location pll_6 because i/o cell "clock" cannot be placed in i/o pin pin_l11 (port type inclk of the pll)
If I try to route the clock signal directly, I get from the fitter :
error (170084): can't route signal "clock~input" to atom "clock~inputclkctrl"
The device is an ep4cgx110df31c7. I am using a clock (processor clock) on pin L11, single ended. I am also using a GXB clock differential LVDS on pins K15/L15 (this one fits), for GXB using differential pins AB4/3 and AC2/1. I konw that this clock isn't the dedicated clock for the corresponding GXB, but it is routed so on the board I was given, so I have to cope with it.
Now, I have several hypothesis :
- either the NIOS and the GXB routing is not possible (due to the RAM for instance)
- or there is a problem with mismatching clocks from pins L11/L15 competing for the same resource (PLL6)
Am I right thinking so ? Any help is welcome. Is there a way to use both clocks simultaneously with the NIOS design ?
Kind Regards.
