这种特性主要是为了解决没有使用mdio进行管理的Phy设备。
首先是设备树,内核,以及内核配置三块。 第一: 设备树: 有两种写法,据测试现在都是可行的: 之前是这种写法, A 'fixed-link' property in the Ethernet MAC node, with 5 cells, of the form <a b c d e> with the following accepted values: - a: emulated PHY ID, choose any but but unique to the all specified fixed-links, from 0 to 31 - b: duplex configuration: 0 for half duplex, 1 for full duplex - c: link speed in Mbits/sec, accepted values are: 10, 100 and 1000 - d: pause configuration: 0 for no pause, 1 for pause - e: asymmetric pause configuration: 0 for no asymmetric pause, 1 for asymmetric pause 现在是推荐这种写法: A 'fixed-link' sub-node of the Ethernet MAC device node, with the followingproperties: * 'speed' (integer, mandatory), to indicate the link speed. Accepted values are 10, 100 and 1000 * 'full-duplex' (boolean, optional), to indicate that full duplex is used. When absent, half duplex is assumed. * 'pause' (boolean, optional), to indicate that pause should be enabled. * 'asym-pause' (boolean, optional), to indicate that asym_pause should be enabled. * 'link-gpios' ('gpio-list', optional), to indicate if a gpio can be read to determine if the link is up. https://alteraforum.com/forum/attachment.php?attachmentid=14009&stc=1 第二是暂时不能使用ltsi版本,建议使用master版本。 第三是内核配置要配置支持该特性:FIXED_PHY。Link Copied
