Flash Programmer error
When I program my flash memory i get an error "Resetting and Pausing Target Processor : FAILED".Is there any need to change my design?
https://www.alteraforum.com/forum/attachment.php?attachmentid=6976
Hi, you are using Quartus < 10.0 and Nios II IDE, right ?
Your are using an Altera kit, aren't you ?
First, uncheck "ignore sysid" in flash programmer options. It is a bad idea to ignore sysid.
Nios IDE have some troubles in programming flash. One solution is to restart Nios IDE.
Maybe you try to program a flash via a wrong FPGA design (bad sysid).
Maybe you have problem with reset signal.
Good luck.
Hi mmTsuchi,
I have unchecked "ignore sysid".
Please explain me the problem with the reset signal...i have attached the sopc design with this post...
