Community
cancel
Showing results for
Search instead for
Did you mean:
Valued Contributor III
Flash Programmer on DE2
Hi Everyone!
I've recently received the DE2 board. It's full of nice things but I want to be able to use it the same way I use the other Altera boards (meaning with the flahs programmer).
When I try to download a design with a read only file system to the device's flash I get an error. I've included the transcript for the flahs programming procedure:
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
#! /bin/sh# # This file was automatically generated by the Nios II IDE Flash Programmer.# # It will be overwritten when the flash programmer options change.#
cd C:/Altera/Dev_Kits/DE2_System/DE2_demonstrations/DE2_Top/software/hello_DE2/D
ebug
# Creating .flash file for the FPGA configuration
$SOPC_KIT_NIOS2/bin/sof2flash --epcs --input=C:/Altera/Dev_Kits/DE2_System/DE2_d
emonstrations/DE2_Top/DE2_TOP.sof --output=DE2_TOP.flash
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS64 --option=DE2_TO
P.opt C:/Altera/Dev_Kits/DE2_System/DE2_demonstrations/DE2_Top/DE2_TOP.sof DE2_T
OP.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
    Info: Processing ended: Mon Mar 06 10:14:34 2006
    Info: Elapsed time: 00:00:04
Info: Command: quartus_cpf --no_banner --convert DE2_TOP.pof DE2_TOP.rpd
    Info: Processing ended: Mon Mar 06 10:14:39 2006
    Info: Elapsed time: 00:00:05
# Programming flash with the FPGA configuration
$SOPC_KIT_NIOS2/bin/nios2-flash-programmer --cable=&#39;USB-Blaster [USB-1]&#39; --sidp=
0x00C81138 --id=2273640461 --timestamp=1141186422 --epcs --base=0x00C80800 DE2_T
OP.flash
Using cable "USB-Blaster [USB-1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00C81138: verified
              : Checksumming existing contents
00000000      : Verifying existing contents
00010000      : Verifying existing contents
00020000      : Verifying existing contents
00030000      : Verifying existing contents
00040000      : Verifying existing contents
Checksummed/read 317kB in 44.4s
Erase not required
00000000 ( 0%): Programming
00010000 ( 0%): Programming
00020000 ( 0%): Programming
00030000 ( 0%): Programming
00040000 ( 0%): Programming
Programmed 317KB in 0.0s
No change to device contents
Leaving target processor paused
# Creating .flash file for the project
$SOPC_KIT_NIOS2/bin/elf2flash --epcs --after=DE2_TOP.flash --input=hello_DE2.elf
--output=epcs_controller.flash --boot=$SOPC_KIT_NIOS2/components/altera_nios2/b
oot_loader_epcs.srec
# Programming flash with the project
0x00C81138 --id=2273640461 --timestamp=1141186422 --epcs --base=0x00C80800 epcs_
controller.flash
00050000      : Verifying existing contents
00060000      : Verifying existing contents
Checksummed/read 92kB in 13.2s
Erase not required
00050000 ( 0%): Programming
00060000 ( 0%): Programming
Programmed 92KB in 0.0s
$SOPC_KIT_NIOS2/bin/elf2flash --base=0x00800000 --end=0xbfffff --reset=0xc80800
--input=hello_DE2.elf --output=cfi_flash_0.flash --boot=$SOPC_KIT_NIOS2/componen
ts/altera_nios2/boot_loader_cfi.srec
0x00C81138 --id=2273640461 --timestamp=1141186422 --base=0x00800000 cfi_flash_0.
flash
Reading System ID at address 0x00C81138: # Creating .flash file for the read only zip file system
$SOPC_KIT_NIOS2/bin/bin2flash --base=0x00800000 --location=0x100000 --input=C:/A
ltera/Dev_Kits/DE2_System/DE2_demonstrations/DE2_Top/software/hello_DE2_syslib/b
ackground.zip --output=rozipfs.flash
verified
# Programming flash with the read only zip file system
0x00C81138 --id=2273640461 --timestamp=1141186422 --base=0x00800000 rozipfs.flas
00110000      : Reading existing contents
00120000      : Reading existing contents
00130000      : Reading existing contents
00140000      : Reading existing contents
00150000      : Reading existing contents
00160000      : Reading existing contents
00170000      : Reading existing contents
00180000      : Reading existing contents
00190000      : Reading existing contents
Checksummed/read 40kB in 1.5s
00110000 ( 0%): Erasing
00120000 (11%): Erasing
00130000 (22%): Erasing
00140000 (33%): Erasing
00150000 (44%): Erasing
00160000 (55%): Erasing
00170000 (66%): Erasing
00180000 (77%): Erasing
00190000 (88%): Erasing
Erased 576kB in 7.0s (82.2kB/s)
00100000 ( 0%): Programming
Program failed at offset 1068F7
Leaving target processor paused[/b]
--- Quote End ---
Has anyone succssfully tried this before ?
On the same subject, does anyone know the reason why a read only filesystem can&#39;t reside in an epcs device ?
Nir
