12604 Discussions
Flash programmer, Nios II Eclipse
Hi everyone!
I can't push on the select buttom's on the flash programmer.
I kill many time to solve this problem, but all does not help for me. My OS is Win 7 x32
Please, help me.
Thanks in advance.
http://electronix.ru/forum/index.php?act=attach&type=post&id=82040
Please, did you solve your issue I have exactle the same one. A can paste the correct path but then also the Add.. button does not work :(
Jan
Have you tried with keyboard : Tab, Tab, Tab to focus on the button and press Space to activate ?
--- Quote Start ---
--- Quote End ---
It does not help. But on other PCs it works. I have discovered that also Open button does not work. It has to be connected with JAVA FileDialog or something. Becasue all other stuff works. :(
