I used the NIOSII_processor_booting_an370 guide
(option 2) to combine an elf- and a sof-file into a pof-file. I put the pof-file into flash and the application ran o.k. However, when I programmed the sof- and elf-file separately I got this error when downloading the elf-file: -- Verify failed between address 0x18080000 and0x1808001F Leaving target processor paused -- Is it impossible to use sof- and the elf-file in this way because of the changes necessary to put them in flash? Thanks, JosLink Copied
