12603 Discussions
Flip-flop by using logic gates
hi
I am a new to VHDL and currently doing VHDL assignment. In this assignment, required to create the D, JK flip-flop.
I need help to solve my error for my code as shown as below:
library ieee;
use ieee.std_logic_1164.all;
library work;
entity Lab1 is
port
J :in std_logic;
K :in std_logic;
clk :in std_logic;
Q : out std_logic;
qn :out std_logic
end Lab1;
architecture arc of Lab1 is
signal W1 : std_logic;
signal W2 : std_logic;
signal W3 : std_logic;
signal W4 : std_logic;
signal W5 : std_logic;
signal W6 : std_logic;
begin
qn <= W4;
W1 <= not (J and clk and W4);
W2 <= not (K and clk and W3);
W3 <= W1 nand W4;
W4 <= W2 nand W3;
process(clk)
begin
if rising_edge(clk)then
Q <=(J and (not Q)) or ((not K) and Q);
qn <=not Q ;
end if;
end process;
end arc;
Error (10309): VHDL Interface Declaration error in Lab1.vhd(41): interface object "Q" of mode out cannot be read. Change object mode to buffer.
Pls help me to solve the syntax error
Two options:
- change Q from out to buffer
- use an internal signal Qi and copy it to Q outside the edge sensitive condition.
Also the assignment for qn must be placed outside the rising_edge() condition, otherwise it's delayed by one clock.
Hi FvM
- use an internal signal Qi and copy it to Q outside the edge sensitive condition?
can show me pls?
process(clk) begin if rising_edge(clk)then Qi <=(J and (not Qi)) or ((not K) and Qi); end if; qn <=not Qi ; Q <= Qi ; end process;
BTW, shouldn't
qn <= not Qi;
Q <= Qi
be outside the process?
--- Quote Start ---
BTW, shouldn't
qn <= not Qi;
Q <= Qi
--- Quote End ---
Yes, they must for correct simulation, or Qi needs to be added to the sensitive list.
Thanks!
