I run the code below using both Nios V processor and online C code compiler,
#include <stdio.h>
int main() {
double total = 5;
int number = 1;
float percentage = number / total ;
printf("%.5f",percentage);
return 0;
Online compiler is working
https://www.programiz.com/c-programming/online-compiler/
Nios V is not working
Could you help me?
I will further duplicate and validate from my side to see whether it's a bug. Will keep you updated if I have any findings.
Thank you.
Kelly
Have you added the hardware floating point component on platform designer to carry out the calculation? If not, the Floating Point Hardware component is under Embedded Processors on the Component Library tab.
We do have NIOS II Custom Instruction guide which should be similar to the application of NIOS V for your reference here: https://www.intel.com/content/www/us/en/docs/programmable/683242/current/nios-ii-floating-point-hard...
Thank you.
Kelly
Can you share the steps to add the library?
As Nios V is still at an early stage of release, we do not have the exact documentation of steps for NIOS V newlib set up. But here is adding the NIOS II new lib which should work the same for your reference : https://www.intel.com/content/www/us/en/docs/programmable/683242/current/nios-ii-fph2-and-the-newlib...
Thank you.
Kelly
Any updates from your side regarding the new information provided?
Thank you.
Kelly
I am still not sure how to add the library, Can you guide me by steps?
Hi Chris,
I just got some news back from the engineering team. Unfortunately support for hardware Floating Point Unit (FPU) is not currently available in Nios V therefore floating point cannot be performed. This feature is expected to be released in future Quartus version.
Thank you so much for posting on Intel forum and I shall set this case to close-pending in the next few days.
Kelly
Hi Chris,
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from the Intel Support is helpful, please feel free to provide ratting with 4/5 survey.
Thank you.
Kelly Jialin, GOH
