i have design for Be Micro MAX10 kit and project with source codes with freeRTOS for NIOS2, which is possible to compile and run, but after first messages Spoustim RTOS. 1.uloha spustena. 2.uloha spustena. 3.uloha spustena. Spoustim scheduler. 3.vSign. 3.vSign Back. 1.vMain. 1.Main arg. 1.Look back. 2.vMoin. 2.Moin, Porter (0 it stops, but i dont know why? In attachment i include the source code, listing of compiler and sopcinfo created by QSYS in Quartus 15.0. I dont know, if the hardware timer is setting ok, if the bsp is setting ok for working with timer functions and/or the scheduler may be bad or stack setting is bad..... Have you somebody some project and design, which works ok ? Thank you for your answer. Jan NaceradskyLink Copied
I include the project for the BeMicro Max10 board, which is low cost:
https://www.arrow.com/en/products/bemicromax10/arrow-development-tools Some idea where could be error ? For this design i was succesfull for compile the basic project for uC/OS2, but it could be fine, when it works with freeRTOS. Thanks. Jan
Topic Options
