I need to regenerate BSP for an old project and I get this error,
SEVERE: Driver not found: 'fifoed_avalon_uart_driver of any version
SEVERE: java.lang.RuntimeException: Driver not found: 'fifoed_avalon_uart_driver of any version
SEVERE: nios2-bsp-generate-files failed.
There is an old forum post about this issue: https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/Eclipse-quot-Generate-BSP-quot-fails-nios2-bsp-generate-files/td-p/39707
However, suggested solutions didn't help. Is there another way to solve this error?
can you please share your platform design file?
Any update?
first check your 'fifoed_avalon_uart_Ip available or not, because you are telling old project, may be in new version that IP not available or available with different name. and regenerate BSP package.
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
