I am able to build an embedded system but I do not know how to use the libraries.
Is there a good manual that helps me to know which libraries should be used with certain embedded hardware ? and the syntax of using it , for example PIO in Qsys, can be programmed to send the data using the library IOWR_ .... and IORD....
Thanks in advance
Refer below links which will help you
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf
https://www.intel.com/content/www/us/en/programmable/documentation/lro1419794938488.html#wnh14894195...
https://www.intel.com/content/www/us/en/programmable/support/support-resources/intellectual-property...
Anand
Much Appreciation,
Thank you
