12604 Discussions
HAL-Driver not included in BSP
Hallo!
I'm currently trying to include a driver into the auto-generated HAL in a BSP. I followed the steps in the "Nios II Software Developers Handbook" from May 2011 (p. 7-20ff).
So I currently have a folder named "ip" in the projects root directory (where the qpf-Project file is) with:
ip
- inc
-- sample_regs.h
- HAL
-- inc
--- sample.h
-- src
--- sample.c
- sample_sw.tcl
I set the "set_sw_property hw_class_name" to the "set_module_property NAME" from the sample_hw.tcl.
But when I create a new BSP for the Nios .sopcinfo-File the files from this driver are not included.
Do you have an idea where I missed something?
Markus
Used Versions:
Quartus 12.1
NIOS EDS 12.1
I found my mistake: It was in the sample_sw.tcl file.
The copied line
"set_sw_property min_compatible_hw_version 7.1"
from an altera sample IP did not match the version 1.0 from my hardware.
So the change to
"set_sw_property min_compatible_hw_version 1.0"
solved it.
Now the source files are in the BSP.
