Hallo!
I'm currently trying to include a driver into the auto-generated HAL in a BSP. I followed the steps in the "Nios II Software Developers Handbook" from May 2011 (p. 7-20ff). So I currently have a folder named "ip" in the projects root directory (where the qpf-Project file is) with: ip - inc -- sample_regs.h - HAL -- inc --- sample.h -- src --- sample.c - sample_sw.tcl I set the "set_sw_property hw_class_name" to the "set_module_property NAME" from the sample_hw.tcl. But when I create a new BSP for the Nios .sopcinfo-File the files from this driver are not included. Do you have an idea where I missed something? Regards, Markus Used Versions: Quartus 12.1 NIOS EDS 12.1Link Copied
I found my mistake: It was in the sample_sw.tcl file.
The copied line "set_sw_property min_compatible_hw_version 7.1" from an altera sample IP did not match the version 1.0 from my hardware. So the change to "set_sw_property min_compatible_hw_version 1.0" solved it. Now the source files are in the BSP.
