Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
HELP PID controller ...Urgent !!!!!
hello everybody
actually i'm working on my final year project that deals with process control which requires the implementation of a PID controller
and i'm wondering if this can be done using VHDL ? if yes please does anyone have a sample code ? Or if there exist an IP Core for PID controller that can be instantiated using SOPC ???
PS: i use nios ii softprocessor and cyclone II fpga of the DE2 board
i really know a little concerning PID controllers
please i really need any help .....it's urgent
thank u very much in advance
Highlighted
If U HAVE SIMULATED DIGITAL PID CONTROLLER USING VHDL THEN PLEASE EXPLAIN ME SIMULATION RESULT.
Highlighted
I have posted vhdl code in my forum...
Highlighted
Software language will be much easier to implement PID controller then using HDL (vhdl or verilog).So you should go for " C " language to program PID controller.
You will find so many readymade codes but important thing is "tuning" and understanding of each parameter effect (i.e P ,I,D) like if "I" parameter is more,then more oscillations will be occurred.So reduce it and increase "P" like that.
I have just recenly done to control my Dc motor.
