Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
HELP:how to remove these timing critical warning
I get some critical warnings for timing,when I make the TSE project.
I want to implement a 150MHz nios II system of TSE transciever,
and I almost finish the hardware of nios II with the DE4 board.
but I get the critical warnings,how to solve it ,help me please.thank you so much
I attach the quartus II archive file,Please help me as your convenience!
the Qsys componets like:
CPU-->
-->onchip memory
-->pipeline bridge 1----> cpu peripherals
-->pipeline bridge 2----> IOs
-->pipeline bridge 3----> ext_flash
-->TSE_MAC
-->SGDMA-tx/rx
-->descriptor memory
thanks again!!
Look for the top failing paths report in Timequest to determine where you need to add more pipelining.
A typical path that needs a pipeline bridge is the one between the Nios CPU masters (data and instruction) and the CPU's JTAG debug slave interface.
Going over 100MHz on a Nios II system on a Cyclone FPGA is possible, but requires some patience...
first thanks for your help.
yes I place a pipeline bridge between cpu and jtag. as :
cpu <----->pipeline bridge <---->[jtag uart,sysid,timer,..]
but these critical warning are for the TSE. so it is a little complicated
and difficult to me.
--- Quote Start ---
--- Quote End ---
You should look at the top failing paths instead. It is in the "Macros" category in Timequest.
If the failing paths are inside the TSE itself, then there isn't a lot you can do, except decreasing the frequency. If it is between the TSE and something else, then there may be something you can do.
