Hello SOC Specialists,
currently I work on a Cyclone V with HPS. Qsys generates a few sdc-files. My problem is, ... a lot of constraints are ignored. If I correct the signal names within hps_io_board_...sdc, those warnings disappear. But there are still more warnings. I suppose the signal names in the wrapper file are incorrect. Maybe they should be the same as the signal names generated by QSYS. I will try it the next time I work in the office. Does anybody know why I get the timing warnings? Is the mistake somewhere else? With kind regards ...Link Copied
