Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
HPS-to-FPGA DMA Interrupt
Hi there,
I am working with the Cyclone V and my goal is to transfer Data with the HPS-DMA-Controller (DMA330) and receive an "interrupt" in the FPGA on completion.
The data transfer is already functioning. I configured the DMA-Controller via the DMAengine-API:
tx = dma_dev->device_prep_dma_memcpy(dma_channel, dma_dst_addr, dma_src_addr, SDMA_BUF_SIZE, DMA_PREP_INTERRUPT ); cookie = dmaengine_submit(tx); dma_async_issue_pending(dma_channel);
However, I do not receive the interrupt in the FPGA.
I checked the HPS-to-FPGA-interrupt in Qsys. Which gave me 8 Interrupt lines corresponding to 8 DMA-channels in the DMAC.
One thing that is not clear to me, that the DMAengine-API "offers" me 32 DMA channels while there are only 8 "physical" DMA-channels.
How can that be?
Currently I am using the API-channel nr. 7 and expecting the interrupt on the physical channel nr 7.
I did a full recompile including SPL and U-boot with Buildroot.
I would like to narrow this down. I guess either
- there is no interrupt sent ( descriptor/ DMA-Controller not properly configured)
or
- it does not reach the FPGA ( I am missing a step where this HPS-to-FPGA Interrupt connections have to be enabled)
or
- I am listening on the wrong DMA-channel-interrupt
Do you have an Idea what is going wrong here or how to proceed?
Do you know any documentation about the HPS-to-FPGA Interrupts other than the "Cyclone V Hard Processor System
Technical Reference Manual" ?
https://alteraforum.com/forum/attachment.php?attachmentid=15575&stc=1
