Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Has anyone used the uC/FS?
Hi all,
I am using a Nios II stratix development board running the MicroC/OS-II. I am wanting to implement a read and write file system in my on board flash. I have started to look at the uC/FS that Micrium has. Has anyone had any experience using this filesystem? Or could suggest another filesystem i could use that doesn't require changing RTOS.
