12453 Discussions
Having a problem when creating a new Nios ii Application and BSP from template
TBroc6
I am following the simple hello world tutorial for my DE0-nano. I am able to select the proper SOPC information file, and cpu. However when clicking finish I get the error:
Failed to execute: wsl dos2unix create-this-bsp;
./create-this-bsp --cpu-name --no-make
I was wondering if anyone had some insight to the source of the error? thanks
MEIYAN_L_Intel
May I know the version for Nios II Eclipse software used?
May I know do you follow the user guide as document below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/tt/tt_my_first_nios_sw.pdf
SHard2
Hi
I am having exactly the same problem, has there been any resolution to this?
Many thanks
Simon
SThor8
There is a, since 2 month, a well known problem with detailed description of the issue with later windows updates and wsl in combination with quartus, see
https://community.intel.com/t5/Nios-II-Embedded-Design-Suite/Error-s0-Error-during-execution-of-quot...
It have been assured that people are working this since early July.
Unless programmers at Intel have 2 months forced vacation it must be a extremely difficult problem that uses almost all resources, working 24h on this.
SHard2
Hi
I have had to support shipping equipment and have not had the time to be able to wait for a solution or experiment to find a work around. I have needed to roll back to 18.1 Build 625 to find a version where it is possible to use the NIOS II tool chain fully.
Every release from Q18.1 update 1 to date appears to have a problem with the NIOS II tool chain.
I am struggling to understand why this appears to be a recurring problem.
Simon
DanielB
Hello, I am attempting the same tutorial and getting exactly the same error.
I have seen various suggestions to fix it on the web, but noe of them worked for me.
Is there a proper fix for this problem?
I am using Quartus II 20.1 Lite, and the recommended version of Eclipse.
Daniel.
DanielB
Hi all,
Well, I don't know exactly what happened, but my Windows decided to do a massive update yesterday evening. After this and the ensuing restarts, it suddenly started working, and successfully created the Hello World project.
If it's important, I started the Eclipse from the Nios II command shell, following suggestions on the web. However, this yesterday also did not work.
Daniel
meenalkb
Hi Daniel,
Would you be able to tell us what version of Windows you are now on? I am also seeing this issue and would like to replicate your "fix"...
Many thanks
Shainy
I face the same issue with Eclipse, and really appreciate if someone could let me know a fix to this. Thanks in advance!
Shainy
praveenkumar
hi shainy  ,
please try with
hello world  small
