12603 Discussions
Hello, we would like to install a plugin at NIOS2 (Eclipse Mars 2, QuartusLite v18.1.0.625) that requires this feature: 'org.eclipse.equinox.p2.operations 2.1.0'. Unfortunately that feature isn't installed. How can I install that feature?
BMäme
We have tried at NIOS2 to install 'Eclipse Platform' (Source: http://download.eclipse.org/eclipse/updates/4.5). That worked for our Plugin, but it destorys and delete some preferences (e.g. C/C++ Build). Do you have any ideas?
Kind regards
Bastian
Ahmed_H_Intel1
Hi Bastian,
Are you sure that this feature is supported by Intel?
I thinks you must reinstall the tool with selecting all features available. Please correct me if I didn't understand your issue.
BMäme
thank you for your support. :)
Unfortunaly i don´t know, if this feature is supported by Intel.
I´ve reinstalled the tool, but ther is no option that all features are available.
I want to install the plugin "Axivion Eclipse Feature".
So I start "Nios II Software Build Tools for Eclipse", then I install via "Install new software" the Axivion Plugin. If I start the installation, the following message appears.
I´ve already contacted the support of Axivion, but they couldn´t helped me.
Ahmed_H_Intel1
Okay, Iwill create an internal ticket to check if the tool supports this feature or not. and if yes, How to install it.
I am seeking for your patience to get this issue resolved.
BMäme
Thank you very much!
I´m looking forward to your answer/solution.
If you have some questions, do not hesitate to contact me!
Regards ,
Bastian
Ahmed_H_Intel1
I am seeking your patience until I get an answer of your question. This is a non standard support which requires much of work.
BMäme
Hey,
many thank for your information.
Can you estimate, when I can expect an answer? :)
Kind Regards,
Bastian
Ahmed_H_Intel1
I apologize for any inconvenience but we still discussing with the Eclipse team to get an answer. I am seeking your patience until they reply to us.
BMäme
do you have any new information for me? Did you get a response from the Eclipse team?
Many thanks for your support. :)
Ahmed_H_Intel1
Actually I didn't get a reply showing if this is supported by Intel.
BMäme
i think, we dont get any futher information from Intel here, do we?
Yesterday i´ve seen, that there will be a new Quartus Lite version released soon. Hopefully this will solve my problem. Do you know, when the version will exactly be released?
