I'm doing gcc compiling on ubuntu according to the tutorial:my_first_hps.
jungu@ubuntu:~/altera/14.0/embedded/my_first_hps$ arm-linux-gnueabihf-gcc
/home/jungu/altera/14.0/embedded/ds-5/bin/arm-linux-gnueabihf-gcc: 18: exec: /home/jungu/altera/14.0/embedded/ds-5/sw/gcc/bin/arm-linux-gnueabihf-gcc: not found
BUT it is there!!!! jungu@ubuntu:~/altera/14.0/embedded$ cd ds-5/sw/gcc/bin
jungu@ubuntu:~/altera/14.0/embedded/ds-5/sw/gcc/bin$ ls
arm-linux-gnueabihf-addr2line arm-linux-gnueabihf-gprof
arm-linux-gnueabihf-ar arm-linux-gnueabihf-ld
arm-linux-gnueabihf-as arm-linux-gnueabihf-ld.bfd
arm-linux-gnueabihf-c++ arm-linux-gnueabihf-ldd
arm-linux-gnueabihf-c++filt arm-linux-gnueabihf-ld.gold
arm-linux-gnueabihf-cpp arm-linux-gnueabihf-nm
arm-linux-gnueabihf-ct-ng.config arm-linux-gnueabihf-objcopy
arm-linux-gnueabihf-elfedit arm-linux-gnueabihf-objdump
arm-linux-gnueabihf-g++ arm-linux-gnueabihf-pkg-config
arm-linux-gnueabihf-gcc arm-linux-gnueabihf-pkg-config-real
arm-linux-gnueabihf-gcc-4.7.3 arm-linux-gnueabihf-ranlib
arm-linux-gnueabihf-gcc-ar arm-linux-gnueabihf-readelf
arm-linux-gnueabihf-gcc-nm arm-linux-gnueabihf-size
arm-linux-gnueabihf-gcc-ranlib arm-linux-gnueabihf-strings
arm-linux-gnueabihf-gcov arm-linux-gnueabihf-strip
arm-linux-gnueabihf-gfortran
I've been struggling for days, I'm new to linux OS. Is there anyone can help me? thanks
You just download it but haven't installed it. You can turn to this page to learn how to build a corss compliation environment :http://www.rocketboards.org/foswiki/documentation/gsrd131gittrees#build_toolchain
I think Jungu uses the arm compiler that comes with SoCEDS package. I'm on Ubuntu, and I'm getting the same issue when I try to compile the hello_world example, Did you solved this issue? If so, tell me, please, how you fixed it! Thanks.- Mark as New
actually I forgot how I fixed this problem. I tried windows OS later. I found there is a mistake in the makefile. I don't whether it can work in ubuntu. You can try this. Here is the makefile code: # TARGET = my_first_hps # CROSS_COMPILE = arm-linux-gnueabihf- CFLAGS = -g -Wall -I ${SOCEDS_DEST_ROOT}/ip/altera/hps/altera_hps/hwlib/include LDFLAGS = -g -Wall CC = $(CROSS_COMPILE)gcc ARCH= arm build: $(TARGET) $(TARGET): main.o $(CC) $(LDFLAGS) $^ -o $@ %.o : %.c $(CC) $(CFLAGS) -c $< -o $@ .PHONY: clean clean: rm -f $(TARGET) *.a *.o *~ Hope you can fix it.- Mark as New
Thank you Jungu for the reply,
I had fixed the issue by reinstalling SOC EDS. Everything is fine now!.
