12604 Discussions
Help: Simple Socket Server - Stratix IV GX
I have a very basic knowledge on FPGAs and Verilog, as I only started to learn about it this semester. my final year project is quite big as I have to implement a PoE structure then make connection with the FPGa board then finally adding a sensor to system. For now I needs to build a simple socket server work on my FPGA board Stratix IV.
I have looked through the forum and found this article, which explains nicely on how to build one
http://www.alteraforum.com/forum/showthread.php?t=28837
but there are things that I did not understand because of different board.
what does this mean (DE2_115_WEB_SERVER_RGMII_ENET0 demo) ad where can I find the demo that is suitable for my board.
honestly I don't know where to start,
please any guidelines will really be helpful .
Thanks You
Look on the web site of the company that made your demo board. They should have examples suitable for your board.
@Galfonz
I have used the web server file of the Stratix IV and I just wanted to run the Qsys file and generate it but it gives me an error though I did not change anything, knowing that the file was for version 12 but it says it can be used in letter versions also, the error is
Error: eth_std_main_system.ethernet_subsystem.tse_mac: Component triple_speed_ethernet 12.0 not found or could not be instantiated
my version is Quartus 15 all other components written used (version 15 instead of 12), but I did not find this component.
Am new in it please guide me
thank you
hi,
it means that the triple speed eth 12.0 is out of date so you ll have to instantiate the newest version from qsys (quartus2 15.0 related) and make the connexions by yourself. in the search bar, look for triple speed ethernet.
--- Quote Start ---
hi,
--- Quote End ---
Hi I have managed to make everything work but it seems that packets are sent from the FPGA but nothing is received... !! what will possibly be wrong ? I used Putty software using Telnet connection in port 30 but nothing seems to appear. though I have no error in the program
please advice
does a ping responds at least?
--- Quote Start ---
--- Quote End ---
No even the ping does not respond !!
post your hdl code please so i can try to help.
--- Quote Start ---
--- Quote End ---
when I run the software this is what I get
https://www.alteraforum.com/forum/attachment.php?attachmentid=12398
Your Ethernet MAC address is 00:07:ed:ff:6b:c7
prepped 1 interface, initializing...
[tse_mac_init]
INFO : TSE MAC 0 found at address 0x0800a000
INFO : PHY Marvell 88E1111 found at PHY address 0x00 of MAC Group[0]
INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0]
INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link...
INFO : PHY[0.0] - Auto-Negotiation PASSED
INFO : PCS[0.0] - Configuring PCS operating mode
INFO : PCS[0.0] - PCS SGMII mode disabled
INFO : PHY[0.0] - Checking link...
INFO : PHY[0.0] - Link established
INFO : PHY[0.0] - Speed = 1000, Duplex = Full
OK, x=0, CMD_CONFIG=0x00000000
MAC post-initialization: CMD_CONFIG=0x0400020b
[tse_sgdma_read_init] RX descriptor chain desc (1 depth) created
mctest init called
IP address of et1 : 0.0.0.0
I don't understand why am I getting that IP address,
the software am running is from altera hardware example designs this is the code that is specifically for the IP address portion
* In our system, we are either attempting DHCP auto-negotiation of IP address,
* or we are setting our own static IP, Gateway, and Subnet Mask addresses our
* self. This routine is where that happens.
int get_ip_addr(alt_iniche_dev *p_dev,
ip_addr* ipaddr,
ip_addr* netmask,
ip_addr* gw,
int* use_dhcp)
IP4_ADDR(*ipaddr, IPADDR0, IPADDR1, IPADDR2, IPADDR3);
IP4_ADDR(*gw, GWADDR0, GWADDR1, GWADDR2, GWADDR3);
IP4_ADDR(*netmask, MSKADDR0, MSKADDR1, MSKADDR2, MSKADDR3);
# ifdef DHCP_CLIENT
*use_dhcp = 1;
# else /* not DHCP_CLIENT */
*use_dhcp = 0;
printf("Static IP Address is %d.%d.%d.%d\n",
ip4_addr1(*ipaddr),
ip4_addr2(*ipaddr),
ip4_addr3(*ipaddr),
ip4_addr4(*ipaddr));
# endif /* not DHCP_CLIENT */
/* Non-standard API: return 1 for success */
return 1;
Another thing that the software asks for the serial number to generate the mac address I couldnt find the serial number on the box so I just enetered random " 111111111111111" number.
So what can I do with the IP address or should i eneter it manually since its a static IP ?
1-is the FPGA connected to a switch or directly to your pc?
2-if it s connected to a switch, ask your admin to give you a mac address related to a IP/DHCP, he will it give to you.
3- GO Qsys and disable PCS options in tse, since you re using an external phy
4- For mac address in software, this example assumes you have this info in an external flash, but you can override it with this (network_utilities.c):
error_t get_board_mac_addr(unsigned char mac_addr) { error_t error = 0; alt_u32 signature; mac_addr = 0x00; mac_addr = 0x07; mac_addr = 0xED; mac_addr = 0xFF; mac_addr = 0x0C; mac_addr = 0x83; return error; }
replace with mac address you get from your sys admin.
the problem should be resolved then
My FPGA is connected directly to PC, so am not using any DHCP client.
do I have to disable the tse if its connected directly ?
and about the mac address do I replace the whole code of that part (error_t get_board_mac_addr(unsigned char mac_addr[6])
i think you don't understand what you are doing there. If you disable tse how could your ethernet link work?
In your case, you have to put IP address directly like this (network_utilities.c) : (i'm not sure since i use dhcp)
int get_ip_addr(alt_iniche_dev *p_dev, ip_addr* ipaddr, ip_addr* netmask, ip_addr* gw, int* use_dhcp) { IP4_ADDR(*ipaddr, 192, 168, 1, 100); IP4_ADDR(*gw, 192, 168, 1, 254); IP4_ADDR(*netmask, 255, 255, 255, 0); /* Non-standard API: return 1 for success */ return 1; }
and yes you should replace the section of code i gave to you, and this one above too.
please read this before trying to continue your project, you need some basis
ftp://ftp.altera.com/up/pub/altera_material/12.0/tutorials/de4/using_triple_speed_ethernet.pdf
--- Quote Start ---
--- Quote End ---
Alright thank you, am really a beginner here.
I appreciate your help
hi,
one question : what is the board you re using?
ps : hold on, this job is not an easy one ^^
--- Quote Start ---
hi,
--- Quote End ---
I am using Stratix IV GX230, I have managed to enable the SGMII because it was showing disabled in the results. I set the (TSE_MAC_PCS_SGMII= 1), I still don't receive anything I can notice that the FPGA sends packets thru the link but nothing is received
you are telling me the fpga not the board. Is that a terasic board or something else or a custom board?
disable pcs option in tse cause you re using an external phy.
Read the manual!!!
Are you using a copper rj45 link?
--- Quote Start ---
Read the manual!!!
--- Quote End ---
It is a terasic board,,
Yes I am using an external PHY but I thought I need an SGMII interface as shown in the manual
https://www.alteraforum.com/forum/attachment.php?attachmentid=12408
and yes I am using the rj45 link
can you try to force your pc to this ip address : 192.168.1.1, gateway is the same as last reply (look above), same for mask. if it still doesnt work, try to force you pc to 1Gb/s or 100M or whatever, but don't let it auto negociate speed. (i read something like this in this forum when someone tried to direct link his pc to his card)
i can't really help you further if it doesn't work. I'm sorry. : (
--- Quote Start ---
--- Quote End ---
Hi I have disabled the DHCP from the BSP editor. Then gave a static IP of 192.168.1.234, then I run it and here are the results,
I have noticed that LED D23 keeps blinking and the RX LED of ENET is blinking too but what does that "yyyyyyyyyyy" mean ????!!!
