Help-load uclinux on FPGA
Dear friends,
Recently I have a try for loading uclinux on FPGA. And I do it as Altera wiki-Install Nios II Linux.
http://www.alterawiki.com/wiki/install_nios_ii_linux
And when I have install the gcc-4.2 and then make commands as list:
--tar xf <path_to>nios2-linux-20100621.tar
--cd nios2-linux
--cd uClinux-dist
--make menuconfig
I was stack in this step,the message is
"make: *** No rule to make target `menuconfig'. Stop."
Any one occured this problem before?Please give some advice.
Thank you a lot!
Davidchaning
Do you do the checkout step?
I have try this step ,but it doesn't make effect.
Did you load .ptf file? You need to do something like
make vendor_hwselect SYSPTF=<path>/my_sopc.ptf
Try this even if the wiki says that this step must be done after. Often I had to type "make menuconfig" before and after "make vendor_hwselect"
are you sure that the hw_select shall be done?
If you follow latest branches (see http://www.alteraforum.com/forum/showthread.php?t=31829), the device tree fashion should be followed. hw_select is the way that was used in the old nioswiki times.
hw_select doesn't work any more
you need to create header file with sopc2swheaders script and use it
The wiki is not updated, some times it is a mix of old and new.
your problem could be missing packages.
Thank u.
I have not got the problem yet.
