12455 Discussions
Help with FPGA-HPS Interrupt on Baremetal Application
I have been working on baremetal application, generating interrupts in the FPGA to be handled by the HPS using the HWLib provided. The problem is, I have initialized everything as per the examples provided, but it seems that the GIC does not register the IRQ. I have my FPGA-HPS IRQs enabled in the Qsys project. So I am wondering what other settings I am missing, cause I thought this would just be a straight forward setup, and I will be processing the interrupts.
If there are examples relating to this I will be greatly appreciative.
Try to check what is the interrupt number you are trying to catch.
To make story short, this is the code:
alt_int_dist_target_set(ALT_INT_INTERRUPT_F2S_FPGA_IRQ3, 0x1);
alt_int_dist_trigger_set(ALT_INT_INTERRUPT_F2S_FPGA_IRQ3, ALT_INT_TRIGGER_EDGE);
alt_int_dist_priority_set(ALT_INT_INTERRUPT_F2S_FPGA_IRQ3, 1);
alt_int_dist_enable(ALT_INT_INTERRUPT_F2S_FPGA_IRQ3);
alt_int_isr_register(ALT_INT_INTERRUPT_F2S_FPGA_IRQ3, my_isr_callback, NULL);
