12600 Discussions
Help with IOWR_32DIRECT and IORD_32DIRECT(
I need some help with the functions IOWR_32DIRECT and IORD_32DIRECT. I made a component in VHDL which simply copies the input to the output. Using the Nios II and the functions IOWR_32DIRECT and IORD_32DIRECT I intend to "throw" a value in this component and expect it in return the same value. However, the result is totally different. Could anyone help me indicating where is the error?
The architecture used has an Nios II, Onchip Memory, JTAG UART and the component that I created.
The codes are:
VHDL (Component):
---------------------------------------------- LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.all; ---------------------------------------------- ENTITY Copy IS PORT (dataIn: in STD_LOGIC_VECTOR (31 DOWNTO 0); dataOut: out STD_LOGIC_VECTOR (31 DOWNTO 0); write_n, read_n: in STD_LOGIC; clk, reset: in STD_LOGIC ); END ENTITY; ARCHITECTURE CompCopy OF Copy IS SIGNAL data: STD_LOGIC_VECTOR (31 DOWNTO 0); BEGIN PROCESS (clk, reset) BEGIN IF(clk'Event and clk='1') then IF write_n = '1' THEN data <= dataIn; END IF; IF read_n = '1' then dataOut<= data; END IF; END IF; END PROCESS; END CompCopy;
C:
# include <stdio.h># include "system.h"# include "io.h" int main() { int i = 1; IOWR_32DIRECT(COPY_0_BASE, 1, i); printf("\nValue: %d\n", IORD_32DIRECT(COPY_0_BASE, 1)); return 0; }
Returned value: 1052681
The "Signals" tab in "Component Editor" are:
name
interface
signal type
width
direction
dataIn
avalon_slave_0
writedata
32
input
dataOut
avalon_slave_0
readdata
32
output
write_n
avalon_slave_0
write_n
input
read_n
avalon_slave_0
read_n
input
clk
clock
clk
input
reset
reset
reset
input
Thank you very much!
Some issues i saw:
  • reset unused (helps to have at least a default value when reading your register)
  • read_n and write_n are low active (compare with 0 instead of 1, or use the high active signals)
  • dataOut is pipelined for one cycle, make sure you have defined one read wait state in qsys/hw.tcl
  • there is no address bus (qsys spans a only one single 32Bit word register map)
  • you are writing to offset 1 (0x4 as byte offset), this is not your (single word) component
It worked! Thank you very much!
Just one more question: do you know where I can find the description of each signal type, of the "Signals" tab in "Component Editor" (Signal Type)?
Thank you
Good to hear that it is working now, here is something to read about Signals: :-)
The Avalon spec:
https://www.altera.com/literature/manual/mnl_avalon_spec.pdf
The SOPC user guide:
https://www.altera.com/en_us/pdfs/literature/ug/ug_sopc_builder.pdf
QSYS in the Quartus II Handbook Volume 1: Design and Synthesis, Chapter 6:
https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/qts/qts_qii5v1.pdf
--- Quote Start ---
The Avalon spec:
--- Quote End ---
Thank you very much! =-D
