Till now I am building linux with tarball. Now I want to go one step ahead and try different versions of kernels, like 3.0 stable and 3.1-rc9.
I obtained git updates with "git fetch origin" in all folders (linux2.6, uClinx-dist..) I go to linux2.6 and used "git checkout v3.0-nios2" The boards folder disappears from arch/nios2 directory. Also I have many different options appears when i run menu gconfig (xconfig not working). How can I obtain kernel version with the boards folder as it is? (I am new to git) where can i find details about buildroot changes?Link Copied
The latest NIOS II Linux uses Device Tree to avoid needing custom headers for each board/fpga configuration, so sometime after 3.0 the boards directory was removed. I think you're using git correctly, it's just that directory is actually not there anymore.
