Nios® II Embedded Design Suite (EDS)
Support for Embedded Development Tools, Processors (SoCs and Nios® II processor), Embedded Development Suites (EDSs), Boot and Configuration, Operating Systems, C and C++
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
12487 Discussions
Hi, Is anyone know how to convert .srec file to .flash ? I tried to work with Nios II command shell with several command lines without success. Thanks, Avi
AReuv
Isaac_V_Intel
Hi Areuv,
Which command lines did you running exactly?
Did you have any error running those lines?
Here is an example of the srec2flash utility.
The command syntax for the srec2flash utility is:
srec2flash <my-program>.srec
The utility outputs the file .flash, which you can download into the Nios development board using the command:
nios-run <my-program>.flash
Generating S-Records for Use with the srec2flash utility.
Can you try this? Let me know if it works!
Here is the original file where I found this info - http://extras.springer.com/2004/978-3-662-06730-7/literature/wp/wp_srec_to_flash.pdf
Best regards.
Isaac.
