12589 Discussions
Hi i want to use the "Listing 14. An example of code that uses the video-out port" of the document: "DE10-Nano Computer System with Nios® II " It describes how to print out a rectangel with characters onto a HDMI display.
JBlec2
Unfortunately i dont know which IPs i need to include in Qsys. I now additionaly try the Monitor Pro Program of Intel but i think like the HDMI TX Demo showed me something is wrong with my little HDMI Display. But ok this is another topic. important would be .. how to find out the correct IPs for Quartus and how connect them , so that the nios can use the given given example .
There is a table of used IPs :
Is this the soluton ? Why dont they write how to connect them ?
I/O Peripheral Qsys Core
On-chip memory character buffer Character Buffer for Video Display
SD Card SD Card Interface
Red LED parallel port Parallel Port
Expansion parallel ports Parallel Port
Slider switch parallel port Parallel Port
Pushbutton parallel port Parallel Port
JTAG port JTAG UART
Interval timer Interval timer
System ID System ID Peripheral
Audio port Audio
Video port Pixel Buffer DMA Controller
Thank you :D
JBlec2
hi , before some weeks I think (!) i found a way to do some hdmi output... but finally my team talked to the hdmi on the hdl level . is there any support for this stuff ? i mean something like a hotline ? because I want to work more with quartus and de10nano - the girl on the phone told me I should use this community ... but answers come really slow :P
Deshi_Intel
Good, you got thing working.
I am sorry there is no hotline service for this forum support.
VIP service like "hotline" or "agent on site support" is typically provided by the Intel sales or distributor where customer purchased Intel FPGA product. But also take note that not all Intel distributor is capable to provide luxury technical support service and most the time also depends on business justification.
Take your case for example, I believed you purchased de10nano board from Terasic. right ? Ideally you should be getting technical support from Terasic directly or whoever agent that sold you the product. However if Terasic doesn't has technical support agent then maybe they will direct you to this Intel FPGA forum.
There are Intel support agent (like me) + other users in this forum community to help out each another to try our best to answer the questions in this forum. However since we are supporting multiple forum cases in parallel hence sometime our respond will be slow and I truely apologize for it.
Sorry and I appreciate your understanding on the slowness of respond.
dlim
Deshi_Intel
I hope I have explained our support challenges to you.
We will try our best to help out on issue cases filed in this forum community.
For now, I am setting this case to closure.
dlim
