High frequency FPGA
I'm using a DE0-Nano board with a 50MHz oscillator for the Cyclone IV FPGA and I'd like to have a 150MHz (or even more) circuit. Can you tell me which FPGA (or board) I can use for that?
You should be able to use one of the onboard plls to multiply the 50 up to 150
How can I do that?
--- Quote Start ---
How can I do that?
--- Quote End ---
Select "Tools->MegaWizard Plug-In Manager", Select "Create a new custom megafunction variation", Click "Next", From the list of "Installed Plug-Ins" select "I/O" then "ALTPLL", select your desired HDL language, name the variation, click next, and fill in the properties.
For more info on this MegaCore and all the others, see the User Guide page ...
http://www.altera.com/literature/lit-ug.jsp
Cheers,
Dave
OK, thank you.
