I'm trying to use SDRAM Controller, the SDRAM CLK need to be shifted (such as -60 degrees), so I have to caculate the phase(ns) between CPU clock and SDRAM clock.
According to the "Embedded Peripherals IP User Guide 2016.06.17" page 2-13, the flowing five values are very important. Clock period tCLK Minimum clock-to-output time tCO_MIN Maximum clock-to-output time tCO_MAX Maximum hold time after clock tH_MAX Maximum setup time before clock tSU_MAX I have went every corner of TIMEQUEST GUI, I can't find any thing that can get me the direct answer to clock-to-output time, hold time after clock and setup time before clock. My QSYS design has a 100Mhz clock, and I know the tCLK should be 10ns. The report datasheet should contain the time values that I want, but I don't know how to convert these rise/fall into tSU, tH, and tCO? CLKIN_50M ->PLL.c[0] 100Mhz nios2 SDRAM Control ->PLL.c[1] 24Mhz ->PLL.c[2] 100Mhz SDRAM CLK with phase shift(-60deg) Setup Times
Data Port Clock Port Rise Fall Clock Edge Clock Reference
SDRAM_DQ
CLKIN_50M 3.776 3.951 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.754 3.929 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.766 3.941 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.740 3.915 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.724 3.899 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.776 3.951 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.759 3.934 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.739 3.914 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.744 3.919 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.736 3.911 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.760 3.935 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.753 3.928 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.726 3.901 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 3.746 3.921 Rise u1|altpll_component|auto_generated|pll1|clk
Hold Times
SDRAM_DQ
CLKIN_50M -3.122 -3.297 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.153 -3.328 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.165 -3.340 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.139 -3.314 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.122 -3.297 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.175 -3.350 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.158 -3.333 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.138 -3.313 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.152 -3.327 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.142 -3.317 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.135 -3.310 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.159 -3.334 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.125 -3.300 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M -3.145 -3.320 Rise u1|altpll_component|auto_generated|pll1|clk
Clock to Output Times
CORE_CLK CLKIN_50M 0.900 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A
CLKIN_50M 0.823 0.796 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.818 0.791 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.823 0.796 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.813 0.786 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.808 0.781 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.798 0.771 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.806 0.779 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.788 0.761 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.789 0.762 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.778 0.751 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.799 0.772 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_A CLKIN_50M 0.785 0.758 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_BA
CLKIN_50M 0.801 0.774 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_BA CLKIN_50M 0.799 0.772 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_BA CLKIN_50M 0.801 0.774 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_CAS_N CLKIN_50M 0.769 0.742 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_CS_N CLKIN_50M 0.803 0.776 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ
SDRAM_DQ CLKIN_50M 0.768 0.741 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.796 0.769 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.762 0.735 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.759 0.732 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.806 0.779 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.783 0.756 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.763 0.736 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.789 0.762 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.779 0.752 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.766 0.739 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.782 0.755 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.769 0.742 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.756 0.729 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQ CLKIN_50M 0.776 0.749 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQM
CLKIN_50M 0.793 0.766 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQM CLKIN_50M 0.793 0.766 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_DQM CLKIN_50M 0.768 0.741 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_RAS_N CLKIN_50M 0.766 0.739 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_WE_N CLKIN_50M 0.790 0.763 Rise u1|altpll_component|auto_generated|pll1|clk
CORE_CLK CLKIN_50M 0.579 Fall u1|altpll_component|auto_generated|pll1|clk
SDRAM_CLK CLKIN_50M 2.955 Rise u1|altpll_component|auto_generated|pll1|clk
SDR_CLK CLKIN_50M 3.390 Rise u1|altpll_component|auto_generated|pll1|clk
SDRAM_CLK CLKIN_50M 2.878 Fall u1|altpll_component|auto_generated|pll1|clk
SDR_CLK CLKIN_50M 3.067 Fall u1|altpll_component|auto_generated|pll1|clk
