12596 Discussions
How can I design RTL top component including sub HLS components?
I have created one component IP using intel HLS and I would like to create a top component code that five components is instanced.
And each instance is timing parallel. Can I put component to top component?
I read resource sharing method in HLS loop optimization technique document.
There is one example about implementation of this technique.
'Using loops to share hardware resources'
void foo(int x) {}
component int bar(){
int arr[3] = {7,12,17};
for (int i = 0; i < 3; i++) {
foo(arr[i]);
Are components instead of normal function possible to be inlined inside the component?
