Hi All,
I have a Top_Level.v design which includes several lower level QSYS generated subsystems. Each QSYS module generated all the simulation modules as well as the "msim_setup.tcl". I was able to simulate the lower level subsystems but now I want to do it at the Top_Level, for which I created a TB. I want to reuse the msim_setup.tcl of the lower modules and leave the .libraries where they are and only point to them from the top simulation directory. I want to minimize editing of the stuff generated by QSYS and simply reuse it all at the top. Can you guys suggest a directory structure and example of simple scripts that would travers down to each QSYS dir. , compile and then "elab" at the top- level including the TB? Thanks :) ShvitzerLink Copied
