12600 Discussions
How to connect CFI with NIOS cpu in SOPC?
Dear everyone,
I want to know how to connect CFI with NIOS cpu in SOPC? Using Avalon-MM Tristate Bridge?
Hope that you can provide me an example project, Thank you very much!
You'll want the Nios II instruction and data master to connect to the tri-state bridge which then masters your CFI flash component. If you look around for example designs for the Stratix/Cyclone 1-3 Nios II dev boards you'll probably find lots of examples. Moving this to the Nios II forum section so that you'll get more embedded folks reading this.
--- Quote Start ---
--- Quote End ---
