12603 Discussions
How to convert from .pof to binary?
Hi all,
I've manged to combine the .sof and my boot-loader into .pof file (via the convert file option in quartus) - and everything is good.
However, for remote updates I'd like to be able to write directly to the EPCS4, which I can do - but I'd need to be able to get the .pof file that I usally program from quartus into a format I understand (binary?) to be able to write some code for the NIOS to write it into the EPCS4.
A means to convert the .pof file to a binary (.rbf?) file would probably do - but I don't know if this is possible?
Is this possible?
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Not shure that I got you right, but
You can create a .rbf file with the "convert programming file" option in the file menu.
Or use quartus_cpf to do it from the command line.
See `quartus_cpf --help` for more details.
the convert programming file can only generate a .rbf from a .sof.
i must convert my design to a .pof, because I add in my loader.hex code using that convert-programming file....
so, I can generate a .pof with my .sof and the .hex file located at the end of the device - good.
and I can generate a .rbf of the .sof (only).
however, there is no combination of the tools/file-types I have come up with to get the .pof into a .rbf (or even intel hex which I could then convert with a wee program).
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif
What about `quartus_cpf -c <project>.sof <project>.hexout`?
You can then use nios2-elf-objcopy to convert the hexout to srec if that&#39;s what you&#39;d rather have.
It works for .pof files too, although I haven&#39;t verified that it creates the correct output.
Thanks for the suggestion. Getting data around sometimes seems like a big riddle - I will try and see what new combinations of file translators/etc gets the end result......
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
I got a reply from a separate mySupport posting... However the chap says that unfortunatly this cannot be done. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif
What I can maybe do is write a nios program to read its serial memory and fire it back at me through the serial port to capture it?
I wonder though - if there is documentation to explain the header formats for a .pof? I don&#39;t care at all for the file format other than to get the bytes to write to the serial memory? In my simple mind all I need to the rules for skipping through the .pof file and extract the binary lumps accordingly?
Any ideas folks?
The riddle of file-formats continues.....
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
Hi all,
I have converted the .sof to a .rbf and written it to the EPCS device. But the FPGA will not boot?
Now, I have verified that the data is written down correctly - and also that the bits are reversed for each byte for example - but no boot.
Is a .rbf file of a .sof okay to write straight to address 0 onwards in the EPCS4?
http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/unsure.gif
This won&#39;t work ... the contents of an rbf and what goes into the
epcs device are not the same ... almost the same ... but they&#39;re not
identical :-(
As I recall, the data packet contents in the pof has what you want ...
the magic "register" bits et. al. I have some old code laying around
somewhere that parses pof/sof and can extract the necessary
bits ... if I can find it, I&#39;ll post it.
--Scott
nice one scott. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
Hi Joe,
I have some good news and some better news ... the good
news is I found the code and can send it to you if you like. The
better news is you don&#39;t need it ;-)
1. Use sof2flash
2. Use objcopy as wombat suggested
E.g.:
$ sof2flash --epcs --input=proj.sof --offset=0x0 --output=proj.flash
$ nios2-elf-objcopy -I srec -O binary proj.flash proj.bin
As an aside, the logical address/data packet in the pof is _NOT_
compressed. Using the steps above however will produce a
compressed bitstream (as appropriate).
--Scott
