Hi all,
During the design of ethernet using EP4CE30 , I need to design a custom tristate controller which contains a avalon MM master and a tristate conduit master . The tristate conduit master will connect to a tristate conduit pin sharer. I want to get a example of tristate controller contain both avalon MM master and tristate conduit master.Can anyone help me? I also design a module as follow , bu t the name cannot be recognized by the tristate conduit master in qsys, and can not be seen in the tristate conduit pin sharer. why? // sram_m.v // This file was auto-generated as a prototype implementation of a module // created in component editor. It ties off all outputs to ground and // ignores all inputs. It needs to be edited to make it do something // useful. // // This file will not be automatically regenerated. You should check it in // to your version control system if you want to keep it. module sram_m ( input wire clk, // clock.clk input wire reset, // reset.reset //s0 interface input wire [20:0] s0_addr, // s0.address input wire s0_rdn, // .read input wire s0_oen, //output input wire s0_cen, //chipselect output wire [15:0] s0_rdata, // .readdata input wire s0_wrn, // .write input wire [31:0] s0_wdata, // .writedata input wire [1:0] s0_byten, //byteenable // tcm interface output wire [20:0] tcm0_address_out, // tcm0.addr output wire [15:0] tcm0_data_out, // tcm0.wdata input wire [15:0] tcm0_data_in, // tcm0.wdata output wire tcm0_chipselect_n_out, // tcm0.cen output wire tcm0_write_n_out, // tcm0.wrn output wire tcm0_read_n_out, // tcm0.rdn output wire [1:0] tcm0_byteenable_n_out, //byteenable output wire tcm0_data_outen, input wire tcm0_grant, // tcm0.grant output wire tcm0_request // .request ); // TODO: Auto-generated HDL template assign s0_rdata = ((tcm0_grant==1) && (s0_rdn==0))? tcm0_data_in : 16'hzzzz; // assign tcm0_addr_out = (tcm0_grant==1 )? s0_addr : 16'hzzzz; // assign tcm0_wdata_out = ((tcm0_grant==1)&& ( s0_wrn ==0))? s0_wdata : 16'hzzzz; // assign tcm0_data_outen = ((tcm0_grant==1)&& ( s0_wrn ==0))? 1'b1 : 1'b0; // assign tcm0_cen_out = ((tcm0_grant==1))? s0_cen : 1'bz; // assign tcm0_request = s0_cen ? 1'b0 : 1'b1; endmoduleLink Copied
