Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
How to do IUL in SOPC 4.2?
I'm porting a Legacy .ptf to NiosII/HAL/IDE/The Works. I see that Interface To User Logic has been tossed in the Legacy bin.
What is the new way? I would think Create New Component, but I don't see timing.
Should/Can I use the Legacy IUL in this case, but not select [] Legacy SDK Support?
Ken
Highlighted
Re: How to do IUL in SOPC 4.2?
Kenland,
There shouldn't be anything wrong with using the IUL, but the future is definitely with the Component Editor.
Also, I don't know what you mean by "no timing" in the CEd. It's there, you have to add your HDL files and then connect up your Avalon ports. Once you've done that, you should see the timing, that you're looking for, for each of the ports that you define.
Hope this helps.
- slacker
Highlighted
Thanks slacker,
I don't have any hdl files. I just want to add some ports, enter the timing and use my peripheral like with the IUL. Only I don't want it to be obsolete.
I see there are new NiosII docs. I'll go read and reread them. The IUL was a true jewel IMO.
Ken
