12452 Discussions
How to install and configure FFTW-3.3.3 that can be compiled by "nios2-linux-gcc"
I want to use fftw-3.3.3 in my nios2-uclinux , I install it follow "fftw installation user manual":
(1)first, verify whether it works well on linux (centos-6.4)
[root@localhost fftw-3.3.3]# ./configure
[root@localhost fftw-3.3.3]# make
[root@localhost fftw-3.3.3]# make install
Edit the PATH:
export path=$path: /root/opt/nios2/bin:/usr/local/bin
export c_include_path=/usrlocal/include
export library_path=/usr/local/lib
After that, I write and compile a testfft.c:
[root@localhost root]# gcc testfft.c -lm -lfftw3 -i/usr/local/bin
[root@localhost root]# ./a.out
--the output is correct! it can work on my linux:).
(2) change to "nios2-linux-gcc"
[root@localhost root]# nios2-linux-gcc -v
--the version is 3.4.6, it's ok.
[root@localhost fftw-3.3.3]# make clean
--clean fftw pre-install
[root@localhost fftw-3.3.3]# ./configure cc="nios2-linux-gcc" --host=nios2
........install........
then copy the "fftw3.f , fftw3.f03 , fftw3.h , fftw3l.f03 ,fftw3q.f03" from " /usr/local/include" folder to nios2 toolchain folder ".../nios2/include"
copy the the "fftw-wisedom, fftw-wisdom-to-conf" from "/usr/local/bin" to nios2 toolchain ".../nios2/bin"folder.
copy the "libfftw3.a, libfftw3.la" from "/usr/local/lib" to nios2 toolchain ".../nios2/lib"
(3) compile testfft.c again:
[root@localhost root]# nios2-linux-gcc testfft.c -lm -lfftw3 -i/usr/local/bin
/root/opt/nios2/bin/../lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/lib/libfftw3.a(mapflags.o)(.text+0x49c): in function `fftw_mapflags':
: undefined reference to `log'
/root/opt/nios2/bin/../lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/lib/libfftw3.a(mapflags.o)(.text+0x4b8): in function `fftw_mapflags':
/root/opt/nios2/bin/../lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/lib/libfftw3.a(trig.o)(.text+0xf0): in function `real_cexp':
: undefined reference to `cos'
/root/opt/nios2/bin/../lib/gcc/nios2-linux-uclibc/3.4.6/../../../../nios2-linux-uclibc/lib/libfftw3.a(trig.o)(.text+0x10c): in function `real_cexp':
: undefined reference to `sin'
collect2: ld returned 1 exit status
--something is wrong, "nios2-linux-gcc" can't compile it .:confused:
the nios2-linux is "nios2-linux-20090929.tar"
the nios2gcc is "nios2gcc-20080203.tar.bz2"
--the nios2-linux is ok, i have verified it on my fpga hardware.
maybe the configuration is wrong, so would somebody give me some suggestions?
thank you very much!
