Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
How to know NiosII IDE version information?
My NiosII IDE help menu only shows "version:1.0.0, Build:316". How do i know whether it is a full edition? And what's the difference between the three NIOS II package?
nios_final.zip
nios2_1.0_eval.exe
nios2_ucos2.exe
<div class='quotetop'>QUOTE </div>
--- Quote Start ---
My NiosII IDE help menu only shows "version:1.0.0, Build:316". How do i know whether it is a full edition? And what&#39;s the difference between the three NIOS II package?
nios_final.zip
nios2_1.0_eval.exe
nios2_ucos2.exe[/b]
--- Quote End ---
OK, I&#39;m only familiar with what&#39;s on CD&#39;s, but I&#39;ll take a stab at this:
nios_final.zip - this would be the shipping full cost Nios II 1.0. What is included in the Nios II dev kits.
nios2_1.0_eval.exe - this would be what went out on the IP sampler CD&#39;s with Quartus 4.1 (???) - that&#39;s a guess. I don&#39;t know where you&#39;re getting the files. If that is where you got this. Or from the web as an eval edition of Nios, then ... Here&#39;s what it says on this forum in the link to download it...
--- Quote Start ---
This edition is the same as the full edition mailed to upgrade customers except that it contains neither the MicroC/OS-II operating system code, nor the GNU source tree.[/b]
--- Quote End ---
nios2_ucos2.exe - no idea. Where do you see this file?
Does this help. The IDE is the same version. Only the files it sees (which come from the Nios component area) are different.
Then how to know whether the programming files and flash programming files
generated are time_limited?
Quartus tells you.
Also, if you don&#39;t have a license, they will be time limited.
