12603 Discussions
How to provide different clock for PHY Device
My board DE2-115
My PHY Device:88E1111
My project is about simple socket server.Now I can send words or command via Telnet or Ping, when I use a router(100Mbps).
But, when I directly connect the board and PC with a cross-over cable , I failed.
Then when I fix my pc for 100Mbps and connect the board and PC with a cross-over cable, I succeed.
So if I want to use 1000Mbps, what should I do ?
I know I need to provide different clock to Marvell 88E1111 PHY Device for different speed. Such as 2.5MHz for 10mbps/ 25MHz for 100mbps /125MHz for 1000mbps.
Who can tell me how to change the clock and where to change the clock,provided for phy device.
It is the first time for me to post a thread, I hope that somebody could help me to solve this problem.
Firstly try to run example project. Maybe Your cable between PC and the board has only two pairs, so the connection is 10/100.
OK, I will use another cable to try.
Thank you so much Socrates!
I wanna ask you another problem.
Now I can transfer data by TCP Server program in NIOS.
But the speed is low,only about 16Mbps.
Is there any way to raise the speed?
PS:The cpu in sopcbuilder is fast.
Nios is relatively slow. How much do You need? Whats the CPU speed?
CPU is up to 113 DMIPS.
I want to be as faster as possible and I need use NIOS, so is there anything I can to raise the speed?
Don't use RTOS, do bunch of optimizations, DMAs, etc... Read the thread about LwIP on Nios.
If you see this thread, try another board!!!
There is nothing wrong with my project, my board is broken!!! When I change to another, I succeed!!!
