12600 Discussions
How to put devtab.h into <cyg/io> ?
Hi!
In io.cdl, I see:
cdl_package CYGPKG_IO {
display "I/O sub-system"
doc ref/io.html
include_dir cyg/io
requires CYGPKG_ERROR
description "
The eCos system is supplied with a number of different
device drivers. This option enables the basic I/O system
support which is the basis for all drivers."
In ecos.db, there is
package CYGPKG_IO {
alias { "I/O sub-system" io }
directory io/common
script io.cdl
There is devtab.h in packages/io/common/current/include.
However, after building, I see no devtab.h file in cyg/io. What may be wrong?
TIA
Is the CYGPKG_IO package enabled in your ecos.ecc file? I see a cyg/io/devtab.h in my projects.
Thanks, Daixiwen! I just did not know that there were several targets in my ecos.db. Now, the problem is solved.
