12603 Discussions
How to "printf" to my 16207 Optrex lcd controller ?
Hi there,
I've spent lots of time on this, but S.O.L.. cant solve this one.
I am trying to output a string of texts (sometimes with integer variable) to my LCD controller using printf() (or similar) through NIOS 2, using Eclipse IDE.
I can verify my connection is good, and my LCD and NIOS 2 works fine too, as i can use the HAL to manually initialize the LCD, delay, and also to output text like the following;
void lcd_init(void){
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE, 0x38);
usleep(1000);
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE, 0x0C);
usleep(1000);
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE, 0x01);
usleep(1000);
IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE, 0x06);
usleep(1000);
void lcd_print(char *pText){
int i=0;
while(pText!='\0') // loop until the eof
switch(ptext
case '\f':IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE, 1);
usleep(2000);
break;
case '\n':IOWR_ALTERA_AVALON_LCD_16207_COMMAND(LCD_BASE, 0xC0);
usleep(1000);
break;
default: IOWR_ALTERA_AVALON_LCD_16207_DATA(LCD_BASE, pText[i] );
usleep(1000);
break;
i++; // get ready for the next character in the string
} // end of while
return;
I wrote these functions, it works well, but it does not take any variable like the following;
lcd_print("the number is: %d", A) .
my function can only output pure ASCII character.
I found some example online that could potentially do this, shown in the following;
FILE* fp;
fp= fopen("LCD_NAME", "w");
if (fp == NULL) {
fprintf(stderr, "open failed\n"); return 0;
fprintf(fp, "The time now is %d", time);
I can't make this code work. my question is WHY??
I don't understand how this code can work, as it does not initialize, and it does not contain any delay. Can anyone correct this?
Thank you.
Michael
In Nios II software build tools (Eclipse), make a new program from example. I am sure there is LCD routine in Web Server example since it shows IP address in the LCD, but You can check board diagnostics or other examples containing LCD control source.
--- Quote Start ---
--- Quote End ---
My LCD routine works now. As you said, i used the code from a template file. But i dun quite understand the template file.
Do you know how this line works??
FILE* fp;
fp= fopen(LCD_DISPLAY_NAME, "w");
am i writing to the internal physical memory of the LCD module?? otherwise where is this file located at?
regards,
Michael
