How to read RS232 ?
Hello all,
I have problem with UART, when i want to read serial data (hex byte message - something like bytes: 02,05,01,02,05 after this 10ms space and 03,05,xx,yy,zz etc.).
I have development kit DK-DSP-EP2S60 and when i connect the board, which send me bytes to the NIOS2 design with uart and in uClinux i use:
fd = open(S0_232, O_RDWR | O_NDELAY | O_NONBLOCK );
fd = open(S0_232, O_RDONLY | O_NOCTTY | O_NDELAY );
and when the program perform this command, the data from RxD RS232 are sended to the output TxD. I dont understand why ? (why it create loopback on RS232)
How is possible to read data from RS232 without loopback ? (how to set RS232 for reading only ?)
Thank you very much.
Jan Naceradsky, Czech Republic
I forgot:
SO_232 is device "/dev/ttyS0"
# define S0_232 "/dev/ttyS0"
Jan Naceradsky
Because the linux driver will be assuming you want tty semantics.
You need to change the tty mode - see 'man termios' (at a guess).
Thank you.
I finally solved it with my collegue which advice me to add command
stty -F /dev/ttyS3 sane -echo -icanon
to rc file. This command stop the echo of input characters.
And after open command in program i use:
void init_rs232(void)
struct termios options;
fd = open(S0_232, O_RDWR | O_NOCTTY | O_NDELAY );
if (fd > 0)
{ fcntl(fd, F_SETFL, O_NONBLOCK);
tcgetattr(fd, &options);
options.c_cflag |= (CLOCAL | CREAD | CS8 );
options.c_cc[VMIN] = 1;
options.c_cc[VTIME] = 0;
options.c_lflag = FLUSHO;
tcsetattr(fd, TCSANOW, &options);
printf("Init RS232 OK.\n");
and now it works well.
Jan Naceradsky
The 'stty' comand probably does nothing useful - I'm not even sure the values persist once the device is closed.
You are already disabling echo and icanon when you set c_lflag.
Yes, you are right, i cancel stty command in linux and use
options.c_lflag &= ~(ICANON | ECHO | ISIG );
in open function:
// fd = open(S0_232, O_RDWR); // | O_NOCTTY | O_NDELAY );
if (fd > 0)
fcntl(fd, F_SETFL, FNDELAY);
options.c_cflag |= (CLOCAL | CREAD );
options.c_cflag &= ~PARENB; // set no parity, stop bits, data bits
options.c_cflag &= ~CSTOPB;
options.c_cflag &= ~CSIZE;
options.c_cflag |= CS8;
But when i read hex message (from PC to Altera NIOS2 system)
16,11,01,00,00,00,00,80,00,7B
the linux read
16,01,00,00,00,00,80,00,7B
and the second byte doesn't receive .... i read the termios on:
http://slackware.osuosl.org/slackware-3.3/docs/mini/serial-port-programming
and they say that 0x11 is DC1 which mean VSTART for XON and XOFF and i am not able to disable this software flow control.
When i use setting
options.c_cflag &= ~(IXON | IXOFF | IXANY); // no flow control
or
options.c_cflag &= ~CRTSCTS;
it doesnt work. Read again:16,01,00,00,00,00,80,00,7B (and the 0x11 is missing).
Do you have somebody program, which can read EVERY characters (hex - 00-FF) without any control meanings ?
Is possible to disable control characters in options.c_cc[xxx] ?
I retype
options.c_cc[VSTART] = 0xFE;
and the message is read ok, but echo was set ... why ?
Where is error ?
Jan, Czech Republic
Hi all,
is anyone who can solve this problem ?
Jan
Are you actually certain the PC is sending the 0x11 byte ?
