Hi,all:
I want to read and write multiple sector of ATA hard disk with nios2,and i can read and write one sector only(the first sector under LBA addressing),anyone can tell me how to do?Following is some code and message:
Code:
Read HD ID:
<div class='quotetop'>QUOTE </div>
buffer2[1]=3fff.=================Number of logical cylinders
buffer2[3]=10.==================Number of logical heads
buffer2[6]=3f. ==================Number of logical sectors per logical track
buffer2[10]=3546.=============Serial number (20 ASCII characters)
buffer2[19]=2020.=============Serial number (20 ASCII characters)
buffer2[22]=4.==============Number of vendor specific bytes available on READ/WRITE LONG cmds
buffer2[23]=332e.=============Firmware revision (8 ASCII characters)
buffer2[26]=2020.=============Firmware revision (8 ASCII characters)
buffer2[27]=5354.=============Model number (40 ASCII characters)
buffer2[46]=2020.=============Model number (40 ASCII characters)
buffer2[47]=8010.============[7..0]00h =Reserved //[7..0]01h-FFh = Maximum number of sectors that can be transferred per interrupt on READ/WRITE MULTIPLE commands(1)
buffer2[51]=200.============[15-8] PIO data transfer cycle timing mode
buffer2[52]=200.
buffer2[53]=7.
buffer2[54]=ffff.=============Number of current logical cylinders
buffer2[55]=1.==============Number of current logical heads
buffer2[56]=1.============Number of current logical sectors per track
buffer2[57]=ffff.==============Current capacity in sectors
buffer2[58]=0.===============Current capacity in sectors
buffer2[59]=10.===========[15-9] Reserved [8]1=Multiple sector setting is valid [7..0] xxh=Current* * * * * * * * * * * * * * * * * * * * * * * * * * * setting for number of sectors that can be transferred per interrupt on R/W* * * * * * * * * * * * * * * * * * * * * * * * * * Multiple command
buffer2[60]=a780.===Total number of user addressable sectors (LBA mode only)
buffer2[61]=254.====Total number of user addressable sectors (LBA mode only)
buffer2[62]=0.
buffer2[63]=407.====[15-8] Multiword DMA transfer mode active[7..0] Multiword DMA transfer modes* * * * * * * * * * * * * * * * * * * * * * * * * supported
buffer2[64]=3.=======Advanced PIO transfer modes supported
buffer2[65]=78.======Minimum Multiword DMA transfer cycle time per word
buffer2[66]=78.
buffer2[67]=f0.=======Minimum PIO transfer cycle time without flow control
buffer2[68]=78.========Minimum PIO transfer cycle time with IORDY flow control
buffer2[80]=7e.=================Major version number
buffer2[81]=0.
buffer2[82]=346b.==================Command set supported.
buffer2[83]=4b09.================Command set supported.[/b]
Help me,please!
Thank you very much.
