12590 Discussions
How to recover Arria 10 QSPI flash daughter card
Hi
I am able to boot the QSPI flash daughter card with the default image. Then i built the QSPI u-boot using the below configuration
make socfpga_arria10_qspi_reva_defconfig
then converted the u-boot-dtb.bin image using mkpimage tool to u-boot-mkpimage.bin
mkpimage -hv 1 -o u-boot-mkpimage.bin u-boot-dtb.bin u-boot-dtb.bin u-boot-dtb.bin u-boot-dtb.bin
then programmed the QSPI flash using below command
tftp 0x8000 u-boot-mkpimage.bin
sf probe
sf erase 0x0 0x100000
sf write 0x8000 0x0 0x100000
I followed the Arria 10 QSPI flash memory map as shown below
https://rocketboards.org/foswiki/view/documentation/a10gsrd161qspiboot
Now the Evaluation board is not booting and how can recover back the flash daughter card ?
Thanks sunshine,
i am able to recover back my flash daughter card using USB Blaster and quartus_hps
jtagconfig
jtagconfig --getparam 1 JtagClock
quartus_hps -c 1 -o PV /home/Desktop/devkit/qspi_image/u-boot-_w_dtb-mkpimage.bin
u-boot-_w_dtb-mkpimage.bin is the default built in binary from rocketboards.org
below is the link for QSPI mapping
Glad to hear that! Thanks for sharing :)
